TwinTurbo.NET: Nissan 300ZX forum - Re: make sure there ae no shorts to ground at the switches
red z 2 b tt
on September 13, 2011 at 8:35 PM
make sure there ae no shorts to ground at the switches (n/m)
posted by sandmanz32
on September 12, 2011 at 09:46 PM
Thanks for all the info. After taking things apart I found a wire between the harness and the trunk pin/sensor wire cut. Easy fix, a lot of time finding the problem.
z32 security light
red z 2 b tt
18:59:48 09/12/11
Sure can - one common issue is the hood trigger switch
jzack
19:11:07 09/12/11
Re: Sure can - one common issue is the hood trigger switch
red z 2 b tt
19:47:53 09/12/11
red z 2 b tt
20:14:50 09/12/11
Re: Re: Sure can - one common issue is the hood trigger switch
sandmanz32
20:28:59 09/12/11
Re: Re: Re: Sure can - one common issue is the hood trigger switch
red z 2 b tt
21:18:08 09/12/11
sandmanz32
21:46:46 09/12/11
Re: make sure there ae no shorts to ground at the switches -
red z 2 b tt
20:35:37 09/13/11
